RCU Forums - View Single Post - RC Drift noob
Old 09-12-2012 | 11:33 AM
narwalrus's Avatar
narwalrus
Default RE: RC Drift noob
Well, we've never actually been there but we do have citizenship :P
12t sound just about right, assuming you're not building this to be "competitive", just fun.
is the chassis the belt driven one or the shaft driven one? Here's the gears I was talking about:
http://driftmission.com/guides/yokomo-cs-gears-guide/
I was looking at the Yokomo gears there. I'm not sure if it's set up 50/50 front/rear on the power distribution, but those will overdrive the rear wheels and make it so you can actually counter-steer like a full-scale car, full left while moving right and such.
I think you might already be running a front one-way:
The kit also provided the parts (less diff balls) to make a front diff if you didn't want to run the front one-way.
I don't use lipo myself (Although I've got one in the mail) however I believe you need to check if the ESC has a voltage cutoff/LiPo compatibility listed. You can attach an external voltage cutoff if it doesn't.
