RCU Forums - View Single Post - Installing dubro hinges in ARF
Old 09-16-2012 | 04:20 PM
PDF
Default RE: Installing dubro hinges in ARF
Hi Ahicks,
I just looked on the Gorilla Glue website and they have (Gorilla Glue) and also (Wood Glue) I'm assuming you are talking about the straight Gorilla glue. How much do you apply in the slot? do you moisten the slot first? and do you put any glue on the hinge, or just the slot and put it in. Also when it does expand does it push the hinge out? and during the expansion period you keep picking it out or do you wait till it dries? I'm thinking of going this route since epoxy is a PIA to work with. By the way is Gorilla glue brittle once dry or is it more flexible?
Thanks for your help,
Pat
