RCU Forums - View Single Post - DLE Engines Electronic Ignition Sensor
Old 09-25-2012 | 09:46 AM
BadAzzMaxx
Default RE: DLE Engines Electronic Ignition Sensor
All the sensors are the same, You just have to make sure you use the right sensor bracket.
There are long and short brackets like in the first picture.
The best is to use the universal if you do not know which one will work for you, They will work with most any engine using RCexl ignitions and some that do not use RCexl ignitions. It is the second picture.
Milton
ID:	1804835   Click image for larger version
