<span style="font-size: large;"><span style="color: rgb(255, 0, 0);">DV4BT: WEA Android APP</span></span>, new version: Beta 14
Use this next BETA (14) of the WEA APP for Android v2.x 3.x and 4.x Smartphones (at your own risk of course)
In this beta-version (14), the BT connection problem that could occur in (13) has been fixed. Now runs really stable on Motorola Defy+ with 2.3.6 and also on CM9 4.0.4 in a distance of over 5m to the DV4BT.
Be sure to set the data format to "telemetry" with Gigacontrol in the Bluetooth-Sction. Firmware-Level in the WEA Components must be v2.5x or up. (For extended BT-Range, you can set the RF output from 0 up to +10db in the same section).
Rename the attached .PDF file to *.APK and transfer it to your Smartphone, then install it by tapping on the file using a file manager. The final version will incoporate MUCH more functionality as the author let us know when he released this first version. This will come along with a new firmware for the DV4BT.
Please (bug)report your expirience here so issues can be fixed...
best regards
Tom
<fieldset><legend accesskey="I">Attachments</legend><table width="10" cellspacing="0" cellpadding="2" border="0"> <tbody> <tr> <td>
Attachment.pdf </td> <td>
</td> </tr> </tbody></table></fieldset>
