ORIGINAL: abrom1
sounds alot better. hsn is about where i had it at 2 turn the lsn leaned on it a little more and it taken the bog out of it and has a snappier throttle response and don't blow oil clean across my shop.....ill richen it a lil bit to be on safe side. building a lil heat in the motor and finally glow plug has a tan color appearing so it'll be fine. sound great and it'll move the yard with a little push start and swear it has wheels on it afterwards. now i need to get home from work so i can put it in the bayou.... i think alot of the problem was trying to tune a cool motor it just wouldn't build enuff heat
You're using airplane fuel with 18-20% oil content, right? You want a little oil spitting from the exhaust even idling.
