RCU Forums - View Single Post - EVSD-5U-PRO Multi-Function Valve help
Old 10-06-2012 | 08:12 AM
  #45
csandt051196
My Feedback: (35)
Default RE: EVSD-5U-PRO Multi-Function Valve help
to all,
I am trying to set up mode 3, but the front door fires out of sequence. I have the main gear doors plugged into
D2 and the front door plugged into D1.
When I click the radio switch for gear down this is what happens:
1) Main gear doors open. (Correct)
2) Gear Down (Correct)
3) Main Gear doors close (Correct)
4) Front door opens <- This is taking place at the wrong time. I can not get the times set for this to happen at any other time.
When I click the radio switch for gear up this is what happens:
1) Front door closes <- This is taking place at the wrong time. I can not get the times set for this to happen at any other time.
2) Main gear doors open. (Correct)
3) Gear up (Correct)
4) Main Gear doors close (Correct)
Any Ideas? Changing times does nothing on the sequencer.
Thanks Scott
