RCU Forums - View Single Post - older brison 3.2 questions & problems
Old 10-07-2012 | 10:46 AM
raron455's Avatar
raron455
My Feedback: (38)
Default older brison 3.2 questions & problems
HELLO, I AM STILL HAVING SOME ISSUES WITH MY OLDER BRISON 3.2. I WAS HAVING PROBLEMS WITH THE ABOVE IDLE AND FULL RPM, I MADE ALL KINDS OF ADJUSTMENTS NEVER FIXED IT SO I ORDERED A NEW CARB. JUST PUT IT ON, GOT IT RUNNING AND IDLING PERFECT BUT MID AND FULL THROTTLE ARE JUST NOT RIGHT, SPUTTERS AND ACTS LIKE ITS MISSING. I TRIED ADJUSTING THE MIX AGAIN, STARTED WITH THE HIGH, TURN IT IN TILL IT STARTS TO FALL OFF, THEN BACK IT OFF ABOUT 1/8 TURN THEN DO THE LOW SIDE, IT ACTUALLY RUNS WORSE THAN MY STARTING POINTS OF 1 1/2 ON THE LOW AND 1 1/8 ON THE HIGH. HAVE NO IDEA OF WHATS WRONG WITH IT. I BOUGHT THIS USED EARLIER THIS YEAR IN A WILD HAIR EDGE. FOR AN ENGINE WITH SUCH A GOOD REP I HAVE HAD NOTHING BUT MISERY. I AM RUNNING A MIX OF 80:1 WITH PREMIUM FUEL AND AMSOIL. ENGINE WILL START AND RUN PERFECT, A QUICK BLAST TO FULL THROTTLE AND IT WILL TRANSITION OK BUT NOT RUN RIGHT AT FULL RPM, BACK IT TO MID RPM AND DONT SOUND RIGHT, BACK TO IDLE AND ITS PERFECT. I CAN USE SOME HELP PLEASE<br type="_moz" />
