RCU Forums - View Single Post - Making a radial out of multiple single engines
Old 10-11-2012 | 07:34 AM
acdii
Default RE: Making a radial out of multiple single engines
ORIGINAL: init4fun
ORIGINAL: acdii
Nochallengeif someone already built it.[&:] Besides if I can pick up 9 engines from swap meets of the same displacement for cheap, then make the mount and gear set, it would be a lot less expensive that way.
Um , , More like 36 engines of the same displacement ..... Best be buyin that lathe and milling machine
( That is , if we're still thinkin bout that B-17 )
Yeah, I was thinking for the proto type, but your right, 36 engines. Hell if I were to get the Lathe and mill, thenhttp://www.agelessengines.com/9cyl.htm
<br type="_moz" />
