RE: Biodiesel in a model engine
Louis,
Our diesel are not true diesel engines, but compression ignition two strokes. The ether is essential for the combustion process to begin.
Our usual fuel mixture is 30% Ether, 25% Castor Oil and 45% Kero.
This fuel mix is for sport use models and is often varied for specific applications. eg racing can be 30/12/58, also using some exotics like TEL and replacing Castor oil with synthetics.
Vintage engines might increase the oil content to protect frail old engines.
You might get better results from a glow engine running on ethanol mix. By choking the carb size right down you may get good consumption results although you'd give up a little power.
Good Luck
Greg
