RE: Sig Ryan STA
Hi VJ, Just noticed that you are working on the landing gear blocks. Sometime earlier you mentioned that you were considering fitting the Robart robostruts as I have fitted to mine. If you are going to install these you will need to purchase them first as you will need to modify the positions of the mounting blocks to the wings so that these struts can be custom fitted. Fitting these Robostruts allowed me to rake the undercarriage foward by about 1 inch which I hope will help with the problem of nose overs on landing, particularly on our clubs grass flying field that at times can be a little long!
