RCU Forums - View Single Post - escapade assembly trouble
Old 10-13-2012 | 03:55 PM
tes21966
Default RE: escapade assembly trouble
I wish I had thought about that at 2AM. After over an hour of undoing and redoing I finally said the heck with it and went with the dual servo option. I am using a small engine (OS 52 Four Stroke) and was worried about CG and sure enough just like you said; TAIL HEAVY. I added some ballast just in front of the fuel tank but I am going to take it out and try your suggestion and move the battery. I should be able to drop most if not all of the extra weight. Thanks alot for the advise.
