RE: New Seagull A6M Zero
Hi Andy, I have done the two servo's on each wing version, which I believe is for when you need to remove the wings for transport. The other version has one servo in the fuse if you dont have to remove the wings for transport. I also used 2 x MG BB servo's for retracts so I could adjust the end points. I used the the standard push rods supplied except on the gear where I used stronger ones.
Herbs
