RE: 8FGS & OPTICAL KILL SWITCH
You use a switch to control the desired channel. One position of the switch puts the channel at one extreme, and the other position of the switch puts the channel at the other extreme. One position should turn the device on and one position should turn it off. You may need to extend the "travel" endpoints in the Function section of the Linkage Menu to get the device to work properly.
