RCU Forums - View Single Post - CDI gr8flyer55
Old 10-17-2012 | 11:38 AM
  #595
gr8flyer55
Default RE: CDI gr8flyer55
Hi Rob.
One of the HV boards has all the parts on the board, but I just bent the leads over to hold the parts in place. Be sure to check parts placement since I did it quickly to pack up the rest of the box.
I like how you trimmed the excess crankcase material from the Homie !! A first class job as always, looking good!
I just use a small grinder, but you used a lathe or milling machine the way the finish looks. My engines are always done in a hurry so I can test, I never take the time to dress them up like you have done.
My hall sensor gets mounted with a worm gear hose clamp so I can adjust the sensor timing, but it holds up very well for me. Other engines have places to use a bolt on mount which I will try to post a picture of for you. Again, not only way to do it, but it works.
John
