RE: SERVO Elevation system for using DB2 or DB3
I would like to see a wiring diagram of this if you could. I would like to post this on my website as a fix for the elevation. Full credit to you of course.
Thanks. This cam elevation has always bugged me. However with the shotgun approach to the IR beam, accurate aiming is not that crucial so this has alway been just an annoyance to me.
Thanks for the fix.
One thing I did find out though. Paralleling a servo with the DBC gives you an automatic recoil servo.. With the switch wired across potentiometer, the gun fires and the servo recoils. This added to what you have down with the elevation sure is helpful for function. It gives guys a couple of options for recoil control.
