RCU Forums - View Single Post - SERVO Elevation system for using DB2 or DB3
Old 10-18-2012 | 08:38 AM
tsull's Avatar
tsull
Default RE: SERVO Elevation system for using DB2 or DB3
HI Dan,
I'm feeling dense. How is a potentiometer wired in with a parallel servo?
After I hook up and thoroughly test the elevation and ACC2 on a rocker switch, I'll draft a diagram and some pictures for you. Happy to help. I believe it will give you a good edge over the Clarke board for people looking for a true elevation/recoil solution with custom sound.
tjs
