RE: New 3 axis stabilization in testing
Hi Harry
True, ET said it was rated for 5A spikes of 10A
I just got around the problem by using a power bus to the servo, problem solved. In my F-4D I got lazy so I just used my Jomar/EMS glitch buster.
You could also just make a harness that you could run your power leads back to you're regulator, power box, or whatever power bus your using.
I would agree with you I would not run 3 or 4 high power digital servos through the unit.
With by-passed power not an issue, works great.
