RCU Forums - View Single Post - Sig Ryan STA
Thread: Sig Ryan STA
Old 10-22-2012 | 05:07 PM
  #304
VincentJ's Avatar
VincentJ
Default RE: Sig Ryan STA
Thanks David and Tim.
Tim the fuse sides were sanded straight across in the jig that I madeand that does <u>not</u> accomodate for the angle of the dihedral in the wing. I haven't tried yet, but my guess is if Iduplicated the shape of the wing and wing saddle cut out accurately there won't be very much of a gap.One could adjustthe angle between the wing and fuse by carefully sanding until both surfacesare parallel to each other ( easier said than done ), but in this case a wing fillet willfill in any irregularities and make a nice tight fit. I will however check and adjust the angle ofwing incidence before and after I make the fillet. I hope I answered your question.
Tim check out this link and it also will shed some light on making tight fitting wing saddles. http://airfieldmodels.com/informatio...dles/index.htm
Earlier this afternoon I placed my order for a cowl from Fiberglass Specialties.http://www.fiberglassspecialtiesinc.com/ Should arrive in a few days...
