RE: Tail motor problem
You will need to check with a Multimeter to see if the voltage is going up as you throttle up. If it is then the problem may be with the motor. Another test you may want to try is only apply right rudder and see if the motor outputs more power or if the motor begins to drop in power the further you move the stick to the right.
Hope this is of help
Paul
