ORIGINAL: KitBuilder
IMO the foam being mentioned is to stiff... and transmits vibration to easily. I have found it best to use carpet padding. Any carpet shop will have all the pieces you need. It's soft, flexible and very vibration absorbent. I double it up around the reciever and tank with some tape
+1 forcarpet padding....some velcro holds the tank onto thepadding just fine. Tack glue paddinginto the fuse with ca or any glue
