RCU Forums - View Single Post - Sig Ryan STA
Thread: Sig Ryan STA
Old 10-26-2012 | 04:57 PM
  #314
VincentJ's Avatar
VincentJ
Default RE: Sig Ryan STA
Well I'm home! Got right to work on getting the landing gear mounts sorted out. I thought it would be better to drill the holes for the 3/16" landing gear wire first. Upon close inspection I noticed that the end of the wire is not at a 90 degree angle, so I replicated the angle by hand so it could be inserted without any binding. If done right as the wire is inserted into its hole the space between the wire and the mounting block should stay equal. In order for the wire to fully seat I used my Dremel tool with the bit shown to ease the inside edge. Worked well...Once I was satisfied with the fit of everything I epoxied everything into place.
ID:	1815099   Click image for larger version
ID:	1815100   Click image for larger version
ID:	1815101   Click image for larger version
ID:	1815102   Click image for larger version
