RE: SisT FW-190 A8 Schwarze 8
Thanks Bob and everyone!
I found this color pattern while searching on wings Palate. From what I have read this was a unit from JG 301 in defense of the reich. I just bought the built up control surface kit for this to lighten up the plane and control flutter. I will post some more shots as I get closer!!!! I will be using the G62 with the CM6 plug and adapter with electronic ignition. Since the plus is shorter I will not need to cut the cowl. I for sure will put the batteries in the cowl area as there is plenty of room.
