RCU Forums - View Single Post - Advice of pushrod exits
Old 10-26-2012 | 08:11 PM
PDF
Default Advice of pushrod exits
Hello all,
After cutting out the pushrod exits for the elevator and rudder, I was going to paint the balsa where the rod came out and then was told they make rod exit covers. I ordered them online and was looking at them tonight, and thought that they would just glue to the surface of the fuse and be done with it. These look like they have to be cut into the fuse balsa, but if I do that I would have to cut the tube that's glued to the fuse holding the pushrod sleeves. Are there any that glue onto the fuse without cutting into the wood. Any advice would be appreciated.
Pat
