RCU Forums - View Single Post - Advice of pushrod exits
Old 10-27-2012 | 06:46 AM
PDF
Default RE: Advice of pushrod exits
I just called my LHS and also inquired after purchasing the pushrod exit covers, he stated that on the ARF you can't cut these in, it's cut before the outer tubes are installed. So I was initially going to paint the inside of the slot with matching fuse color, so I may have to stick with my initial plan. Are there any other tips that you modelers use to neating up the slot I had to cut to exit the pushrods (about 5/8") long.
Thanks again,
Pat
