RCU Forums - View Single Post - Advice of pushrod exits
Old 10-27-2012 | 07:29 AM
jaka
Default RE: Advice of pushrod exits
Hi!
Never uses the stuff!
Just cover the plane with plastic film (Oracover is best) and take up what ever holes you like.
Using internal set-up linkages is much neater (Pull-Pull , fishing steel vires) as in the blue trainer below, where I have fishing wires on the side rudder and a balsa pushrod to the elevator.
ID:	1815245   Click image for larger version
ID:	1815246   Click image for larger version
ID:	1815247   Click image for larger version
ID:	1815248   Click image for larger version
ID:	1815249   Click image for larger version
ID:	1815250   Click image for larger version
ID:	1815251   Click image for larger version
ID:	1815253   Click image for larger version
ID:	1815254   Click image for larger version
ID:	1815255   Click image for larger version
