now, sense you said you have a round cowl that is the problem,to much air and no were to go.run the vent line out the bottom of cowl,in between the landing gear.solder a brass tube to the diaphragm cover,at the other end of fuel tubing put a two inch piece of brass tube,pinch one end shut,drill two small holes one inch apart in tube.your troubles are now over.
