RCU Forums - View Single Post - ARF Stick Bashing
Old 09-10-2003 | 11:38 PM
Dauntae
Default RE: ARF Stick Bashing
Cut the wing in two and put in 3 inches anhedral, 1 1/2 each side. Use some aileron stock as a wedge and fiberglass cloth on the center section. Now it'll fly knife edge without rolling out. And do better outsides. I have a Joss Stick like this.
Put in a larger engine, like a .61. Even an older one with a 12-7 prop will really spice up your Stick. If you do, consider mounting the rudder servo in front of the fin and use pull-pull to help balance without adding weight. The pull-pull will help you hold the rudder over in knife edge. You also might consider a more powerful servo for the rudder.
Give it some 2 inch wide ailerons and a 3 inch wide elevator.
Well I have 2 3/8 on the ailerons and planned on the elevator but did not know how much I should go, I am putting a OS 46FX on for now but I do have the YS 63FZ from my late Ultrasport [sm=crying.gif] But for now I will use the 46 since I have 4 of them and only one in a plane, Gotta finish building things for these engines. What type of wing does the Joss Stick, semi symetrical or fully symetrical, This one has the fully symetrical so the dihedral adding makes me wonder but if the Joss Stick has full I just might have to try it.. Thanx for tips.
Dauntae
