RCU Forums - View Single Post - Brison 3.2
Thread: Brison 3.2
Old 10-29-2012 | 09:08 PM
BubbasanJohn's Avatar
BubbasanJohn
Default RE: Brison 3.2
Rick, ok. I'll admit I know little about the internal combustion engine. I do know I like them in my airplanes and automobiles. So I did a little looking on the web and now I have a few more questions if you don't mind to better understand my brison.
So from my reading, a piston ported engine is the simplest design 2 stroke? Can it have a reed valve or does it use a rotary valve? Or other valve type? I was assuming the zenoah was piston ported as it sounds alot like the Brison. Are their advantages between reed porting and piston porting?
Thanks for your time.<br type="_moz" />
