RE: Pushrod Clevis Solder ?
Seldom do solder clevis anymore as I use a different set up on pusnrods but when I did I preferred to use 60/40 Acid core as it is easier to solder the pushrod or piano wire with rosin core. Of course not for electrical and use a water wash cleanup.
Acid core is also ideal for soldering wheel collors on axles or soldering washers for wheel retainers.
John
