RCU Forums - View Single Post - Pushrod Clevis Solder ?
Old 11-02-2012 | 01:38 AM
Luchnia's Avatar
Luchnia
My Feedback: (21)
Default RE: Pushrod Clevis Solder ?
ORIGINAL: JohnBuckner
Seldom do solder clevis anymore as I use a different set up on pusnrods but when I did I preferred to use 60/40 Acid core as it is easier to solder the pushrod or piano wire with rosin core. Of course not for electrical and use a water wash cleanup.
Acid core is also ideal for soldering wheel collors on axles or soldering washers for wheel retainers.
John
Curious, since you seldom solder clevis what type of setup do you use now and do you find your current method much easier, better, or just don't desire to use solder? I have never had a solder joint fail on a plane, but then again I am not an extremely agressive flyer either.
