RCU Forums - View Single Post - New Moeibus 1:72 Skipjack
Thread
11-02-2012 | 03:21 PM
15
herrmill
Aug 2006
1,994
Hangzhou, China
RE: New Moeibus 1:72 Skipjack
Development of the Moebius Models 1/72 SKIPJACK Model Kit and its Conversion to R/C Operation, part-4
By David Meriman
A Report to the Cabal:
This one's dedicated to my East Coast model submarine buddies, like Ray Mason, sitting in the dark, waiting for the lights to come back on and the water to depart. Hang in there, guys!
Parts one through four serve as preamble to the meat of this series, a detailed discussion an instruction manual, if you will on how to employ the Caswell-Merriman Moebius 1/72 SKIPJACK fittings kit to convert the static display plastic model kit to a practical, well running, and robust r/c model submarine.
I had little input as to how the kit was engineered. The only input I had was to ask that there be a longitudinally running, horizontal break between the hull pieces, be they two long ones, or the top and bottom halves divided into quarters. This to achieve a removable upper hull half to afford internal access for r/c versions of the model. I also asked that the hull pieces be of substantial thickness (3/32" the ideal); that the lower and upper hull halves or quarters be outfitted with internal stifening frames; and that there be provided a tight fitting system of pins and tongue-in-groove hull edges that would insure positive registration of the two removable hull halves. Other than that, the guys at the point of manufacture did all the engineering and what a wonderful job they did: a sturdy, well fitting, easy to assemble plastic model kit with the minimum of parts.
The mock-up SKIPJACK kit though fabricated in a 3D machine was broken down into parts and the parts indexed as the eventual kit would be. Inspection of the mock-up kit revealed that my wants had been incorporated. I was delighted as in this game you have to be ever mindful that the product is primarily targeted at the vast majority who will only assemble the kit for static display. Fortunately the things I asked for did not impact on the cost of the kit, so they were incorporated.
So, with my work for Moebius completed, I directed my considerable talents and good looks to service to the Caswell empire the design, fabricate, and packaging of r/c conversion kits needed by our customers who wish to turn the Moebius SKIPJACK into a well running r/c model submarine. Before the kits hit the West Coast I had completed all the fittings kit masters and tools, and was well underway with part production. I could do that as I made use of the second generation test-shot kit parts to give form to the masters that were conformal to the inside surfaces of kit parts. Masters were built up from test-shot kit parts (all the control surfaces) automotive filler, brass, plastic sheet, RenShape, foam-core PVC sheet, and white-metal castings.
Below is a visual presentation of the items that make up a Moebius 1/72 SKIPJACK fittings kit, along with a table below denoting the name and function of each item:
A stern planes and yoke
B rudders and yoke
C after Sub-driver foundations
D Sub-driver shock absorber
E forward Sub-driver foundation
F nest transverse bulkhead
G nest keel piece
H torpedo tube nest foundations
I torpedo muzzle bulkhead
J propeller shaft foundation
K propeller
L propeller shaft, bearings and coupler
M hull rudder hole blanking discs
N sail plane operating shaft bushings
O hull stand hole blanking pieces
P Sub-driver restraining strap foundation
Q sail planes and bell-crank
R sail-to-hull mounting foundations
S sail plane bell-crank shaft retainers
T sail plane bell-crank
U mechanical fasteners
V after radial flange
W forward radial flange
X upper hull securing screw and foundations
The first area I addressed as I went about the chore of creating masters was the stern. Specifically, the two-piece foundation needed to mount the propeller shaft bearings. I started by removing the strengthening rib and single longitudinal brace in that area of the two stern hull quarters. I CA'ed a half-circle sheet-plastic transverse damn forward and a blanking sheet butted against the after end of the hull, where the base of the propeller hub would fit. These dams to contain the thinned down filler used to give form to the foundation masters.
I waxed the inside of the containment to prevent the hardened filler from sticking to the styrene.
I thinned the filler with lacquer thinner till the mix was runny enough to insure a bubble-free fill of the stern areas with the gooey stuff. I mixed in a little hardener, poured and pushed the stuff into the stern areas and waited for the filler to cure.
Automotive filler will shrink a bit if used straight out of the can, Even more when you cut it with thinner. So, I was compelled after the two halves of the propeller shaft foundation master cured to pull them out, re-wax the interior of the hulls, smear un-cut catalyzed filler on the contact face of the masters, and smashed them into place, where they remained till the filler had hardened. The glaze I put on the parts made up for the shrinkage and produced a tight glove fit to their respective spots on the hull stern pieces.
The two halves of the filler formed propeller shaft foundations were marked out. Filed out those channels would form the bore through which two propeller shaft Oilite bearings would fit. Extreme care was taken to insure that the centerline of the two channels ran perfectly in alignment with the hulls longitudinal axis.
To make the reach of the long pushrod between the after end of the Sub-Drive (the watertight cylinder containing the propulsion, ballast, and control sub-systems) motor-bulkhead a simple one, I employed a partial bevel-gear linkage within the sail to translate the axial motion of the pushrod (mounted up against the inside of the upper hull) to the rotary motion, up within the sail, needed to operate the sail plane operating shaft. The masters of the two partial gear elements are seen here. A small cylindrical magnet within the eventual cast resin lower gear element engages a magnet at the forward end of the sail plane pushrod. A similar magnetic coupling at the after end of the pushrod produces a near slop-free linkage between servo and sail planes.
These masters, along with the others, would be de-greased, cleaned up, (pickled, if metal), primed, then used to make rubber production tools.
I needed solid foundations within the forward and after bottom ends of the sail through which securing machine screws would hold the sail down upon the hull permitting removal of the sail from the hull for sail plane linkage and snorkel induction head valve and float adjustment or maintenance.
The masters of those foundations formed like the propeller shaft foundation masters from thinned down two-part automotive filler poured into the area of the model part where the eventual model part would fit. Here I've formed the containment dams from oil-based modeling clay. However, with these, the last step was to assemble the two sail halves and hold them tight with masking tape as the last application of filler, applied to the outboard faces of the foundation masters, acted as an adhesive to form two solid foundation masters.
As I worked up the masters for the Moebius Models 1/72 SKIPJACK fittings kit, I developed the jigs, templates, and plumbing masters needed for production of a dedicated 3.5" diameter, SAS type, single-motor SD to handle the ballast, control, and propulsion of this kit.
I used my old, faithful Scale Shipyard 1/72 SKIPJACK model as the evaluation hull as I modified and eventually froze the design of the new SD.
I fabricated the stern plane operating shaft yokes and the rudder operating shaft yokes from brass rod. Here I'm checking the yoke masters as well as an assembled propeller assembly with mock intermediate drive shaft to check for non-interference of the control surfaces through they're full 35-degree travel up/down, left/right. Once all was found to operate properly, the yokes were removed, fillets built up with CA and baking soda, pickled, primed, used to make a disc type metal casting centrifugal tool.
Most of the masters are now in primer gray and ready to produce the production fittings kit tooling.
The first set of fittings kit production tools were made from relatively hard BJB Inc., TC-5050 silicon, platinum cured, room temperature curing (RTV) rubber. The relatively 'hard' rubber is best suited to hold the masters when the time comes to make duplicate tools or copy masters. More on that, maybe, at a later date.
This shows the four two-piece production tools used for resin part production. Note that the control surface cavities have been outfitted with brass operating shaft inserts, as well as brass rod mandrels in the torpedo launcher foundation tool, and a brass pivot pin in the 'accessories' tool. The inserts will be partially encapsulated in the hard resin and become operating shafts, pivot pins, and cylindrical bores.
With all inserts in place I spray in some Mann-200 mold release spray, dust on some talcum powder (a 'bubble getter'), assemble the halves of a tool, sandwich each tool between wooden strong backs, and clamp the assembly tight with rubber bands. Catalyzed resin is poured in through a single sprue hole where it is distributed to the cavities through a system of runners displaced air is routed out of the cavities through a separate vent-channel system. I'm a master at rubber tool design.
The Mann-200 keeps the polyurethane resin from sticking to or attacking the rubber (but not completely, these tools have a 100-200 cycle life before becoming too brittle for use). Talc acts as a wick to pull resin into portions of the tools cavity that otherwise would trap and hold air pockets, which evidence on the part as pinholes.
A fifth production tools, not shown here, is a disc-shaped tool that is spun in a modified blood separation centrifuge while molten white metal is poured in. Another virtue to the TC-5050 is its ability to handle low-melt metals of working temperatures below 600-degrees.
Most of the Caswell-Merriman 1/72 SKIPJACK fittings kit is fabricated from cast polyurethane plastic some of those raw shots seen in the center of the table. I remove the individual parts from the trees, machine back the stubs, and file off most of the flash. No attempt is made to de-grease the resin parts, I leave that for the customer.
This disc-shaped rubber tool is spun in a modified blood separation centrifuge as molten white metal (an alloy of Tin and antimony) is poured in through a sprue hole at the center of rotation. Rubber mandrels set within the cavities form the bores for the stern plane and rudder operating shafts. Another virtue to the TC-5050 is its ability to handle low-melt metals that can be poured successfully at a temperature below 600-degrees.
Once the yokes are snipped away from they're runners, the mandrels are pulled and each yoke is drilled and taped to receive the operating shaft retaining set screws.
The white-metal SKIPJACK propeller both the Moebius kit and the Caswell-Merriman r/c conversion fittings kit represent the original five-blade 'power' screw starts life as a gravity poured white-metal casting, which explains the long sprue on the center propeller. Tall to take advantage of the pressure head produced when pouring the molten metal into the screw cavity of the mold: the taller the sprue, the more hydrostatic pressure at the bottom of the tool, the more inclined the metal is to seek out and fill all cavities within the tool. Also, the tall sprue acts as a header in that it serves to provide make-up material should there be a leak across the flange face of the two tool halves.
Shrinkage is not an issue with white-metal which actually expands a bit during the state change from liquid to solid the Antimony expands in volume when it freezes.
To the left is a propeller casting with the excess sprue cut off on the band saw. To the right is a finished propeller whose excess sprue has been turned to the proper pointed dunce-cap shape. Note the assembled Oilite bearings and thrust washers, propeller shaft, stainless steel thrust washers, and Dumas style universal coupler. The screw is secured to the propeller shaft with a transverse 6-32 X 1/8" SS set screw.
Reply
Like
herrmill
View Public Profile
Send a private message to herrmill
Find More Posts by herrmill
View iTrader Profile
