RE: How to layout mount dle-55
Match the center line of the template with the center lines on your firewall, yours is compinsated fo right thrust, so the drive washer of the engine ends up centered in the opening in the front of your cowl. you can check this by taping the engine mounting template to the firewall, bolt the engine to the standoff's, and holding the fuss verticle, set it on top of the firewall, with the standoff's centered on the mount hole locations on the template, then fit your cowl (leave the muffler off for now to eliminate interfearance) Everything should line up.
