RE: need engine recommendations, please
I agree that warbirds should be flown scale ,but I also understand the need for speed .
I would see where the plane balances with the DLE 20 if more nose weight is required make it usefull use a DLE 30 if it will fit . You get more weight up front if needed and you get more power to go faster . You can always reduce speed with throttle management .
