RCU Forums - View Single Post - GP Waco?
Thread: GP Waco?
Old 11-05-2012 | 08:37 PM
  #1079
kochj
Default RE: GP Waco?
Thank you for the comments...Sandy
I had the same issues with my Chipmunk and the twin's carb ( it is the older airbleed style) and the tank located too high...
I have had many thoughts on converting it to gasoline w/walbro carb...but Idealy it should have 1-carb per cyl... so 2 carbs total...
Would be a tight fit.. or very clever placement...
The Twin is already spark ignition... from the original C&H ignition.
I had also thought about doing a perry pump, and rout the oil outlet through a catch container prior to going through the perry pump...
I would have to open the catch can and drain it occasionally...
Perhaps one could use a I-V style bag for fuel tank??? This would keep the fuel low, and never change position in relation to the carb-fuel tank line...
I have thought about that from time to time.. but fuel draw may be a issue... due to no clunk??? I guess I should post that q in a dif. forum post!...
