RE: Pull pull setup ?
Hi!
I use thinnest possible 17 lbs wire on my 50cc gas airplane (side rudder)!
All adjustments are done inside the fuselage.
The adjusters are just 2mm steel rods hammered flat at one end and then drilled with 0,75-1,0mm drill bit.
