Well here is the Enforcer ready for its fist flight. If the weather holds out then this weekend I will bet ready to go.
Outstanding!!
You will absolutely love it but pay attention to the CG as mentioned. If it appears overly pitch-sensitive you'll know it might need the CG moved forward; OTOH, if it tucks its nose down in a turn then it's likely nose heavy. I have a set of Enforcer foam cores I whacked out and I'm thinking real serious about building another one with a little WREN in it over the winter (which looks like it will start for us this weekend in the high country).
Mike
