RCU Forums - View Single Post - Need airfoil file
Old 11-14-2012 | 12:58 PM
Timthetoolman1's Avatar
Timthetoolman1
Default RE: Need airfoil file
I apply the glass to a sheet of Mylar and then vacuum the whole assembly together. It's a method I use to limit the amount of epoxy soaked up by the contest balsa.
Another method that the FIA guys use, that doesn't require a lot of equipment, is to spray the wing sheeting with hair spray and let dry before adding glass and resin.
Tim
