RCU Forums - View Single Post - New 3 axis stabilization in testing
Old 11-19-2012 | 07:33 AM
  #45
Eddie P's Avatar
Eddie P
Default RE: New 3 axis stabilization in testing
Wow, great info guys. Duke, that's pretty great intel on this unit. Are you saying that if, for example, you have your jet programmed on the bench with specific end points to accommodate structural limits of control movement and linkage peculiarities...
1) If Max aileron on the jet is set at 90 percent servo throw of the servo for example, as intentionally limited by "end point" adjustments in the transmitter itself...
2) Will the Eagle Tree command more throw than the "90 percent end point" if it commands max rate for whatever reason and feels the transmitter set up control throws will not command this rate? (will it actually try to over drive the servo to beyond what the transmitter itself has, as the max limit of the servo at 90 percent per the setup)?
3) So the end points ont he transmitter can be over ridden? And if this is the case, what about if you have your end points set at 110%? Will the Eagle Tree simply only command 100 percent as a max rate command or will it command a much higher number if it feels the need for more rate?
Thanks guys.
