ORIGINAL: 2wheelfiddler
By the way, is there any way to check if the remote is working correctly? If it does and the problem is the receiver, can I just change the receiver and keep the same remote and servos?<br type=''_moz'' />
there isn't an easy way to specifically check if the trans. is working properly or not without swapping out the receiver, transmitter or both....
but, as long as the replacement receiver is compatible with your transmitter, on the same frequency and Modulation (as was pointed out :^) ) you can use the same transmitter, servos etc with a different receiver.
