ORIGINAL: amermehio
I ALREADY HAVE A MOTOR WITH IT . BUT I WANTED TO KNOW WHAT PLANES CAN I USE IT ON CAUSE I THINK IT WOULD BE HOUSED IN THE FRONT OF THE AIRCRAFT SO THAT YOU CAN START THE ENGINE IS THAT RIGHT??. ALSO IF U HAVE ANY BLUEPRINTS FOR MAKING THE PLAE OR WHERE CAN I BUY ONE PLEASE HELP
If it is the motor that is mounted in the fan I doubt you can get that one to run without a serious overhaul and bearing change. It looks heavilly corroded.
Best of luck, Bart.
