Reload this Page >
bauer modelle ducted turbine fan
Old 12-04-2012, 07:16 AM
amermehio
Default bauer modelle ducted turbine fan
i have an old bauer modelle ,impeller bm40/81,ducted fan bm40/81, turbine bm 40/81 does anybody know anything about it (how to start it .......)
Old 12-04-2012, 08:49 AM
frema
Default RE: bauer modelle ducted turbine fan
i should say ,give us some pictures
then maybe i can help you
Regards,
Martin.
Old 12-04-2012, 12:15 PM
amermehio
ID:	1826531   Click image for larger version
ID:	1826532   Click image for larger version
Old 12-04-2012, 12:20 PM
frema
oke thank you
i am sorry that is not the thing i am into
i am only into turbine engines
hope you find someone who can help you
Regards,
Martin.
Old 12-04-2012, 12:49 PM
chrigui
is an old german pusher fan... for 2 stroke engine like rossi FAN 81 or 90 or os 77 91 vrdf or rossi 65 FAN or rossi 53fan
an improvement of this was GLEICHAUF FAN
Old 12-04-2012, 11:02 PM
amermehio
on what type of plane can i put it on .is there any design dwgs for the plan or some blue prints
Old 12-04-2012, 11:07 PM
chrigui
can you take dimension diameter about propeller? 125mm?
Old 12-05-2012, 01:38 AM
amermehio
YES IT IS 125MM
Old 12-05-2012, 01:45 AM
amermehio
ID:	1826870   Click image for larger version
ID:	1826871   Click image for larger version
Old 12-05-2012, 01:48 AM
chrigui
Then you can use ROSSI 53FAN or ROSSI 65 FAN or max 77/80 fan engine
Model under 5kg weight
this was my ZMODEL F-104 powered by ROSSI53FAN and GLEICHAUF MINI (125MM)
Old 12-05-2012, 02:05 AM
amermehio
I ALREADY HAVE A MOTOR WITH IT . BUT I WANTED TO KNOW WHAT PLANES CAN I USE IT ON CAUSE I THINK IT WOULD BE HOUSED IN THE FRONT OF THE AIRCRAFT SO THAT YOU CAN START THE ENGINE IS THAT RIGHT??. ALSO IF U HAVE ANY BLUEPRINTS FOR MAKING THE PLAE OR WHERE CAN I BUY ONE PLEASE HELP
Old 12-05-2012, 02:09 AM
chrigui
All Bertella plans are made for 125mm fan
Or old gleichauf models like F100 or T-2 buckeye
Old 12-05-2012, 03:37 AM
RUFTER
RUFTER's Avatar
ORIGINAL: amermehio
If it is the motor that is mounted in the fan I doubt you can get that one to run without a serious overhaul and bearing change. It looks heavilly corroded.
Best of luck, Bart.
Old 12-05-2012, 03:57 AM
amermehio
WHAT DO U RECOMMEND ME TO USE TO CLEAN UP MY ENGINE . AS FOR THE BEARINGS I THINK I HAVE EXTRAS STILL IN THE BOX NOT USED
Old 12-05-2012, 04:37 AM
BaldEagel
BaldEagel's Avatar
Nitromors or any paint stripper will work, just don't leave it on too long.
Mike
Old 12-05-2012, 05:25 AM
chrigui
Here old video about XZMODEL F-104 with 125mm pusher fan (gleichauf) and rossi 65
video taken on GROSSETO AFB (home of ITALIAN STARFIGHTERS)
[youtube]http://www.youtube.com/watch?v=0vsNkeEA1hg[/youtube]
