RCU Forums - View Single Post - Scale looking Pull-Pull hook up
Old 12-06-2012 | 02:36 PM
BobH
Default RE: Scale looking Pull-Pull hook up
the full sized air craft uses swaged cable that goes through the horn. That's depending on the plane. What aircraft is it?
If you want to make your cables adjustable put the threaded coupler on the servo end not the flying surface end. It'll look much neater.
