ORIGINAL: husafreak
What are the pro's and con's of running a Tamjets pipe? I know they are very light. I will be using the Derjet cockpit and I figure I should get those two things initially. That way I can ensure the equipment install will not interfere with the cockpit tub and I can pick and position the lightest batteries to power everything. I will be running smoke so with that and the cockpit adding weight Tams pipe and those batteries can subtract some.
I have a Tam's pipe in mine, no drawback that I can see other than the additonal cost. Can't remember how much exactly but there was a substantial weight savings over the stock pipe.
Mike
