Need info on a replacement motor
I have a motor with the following numbers: 30-20-1350KV Brushless
I need one that has more power. This one works but it just does not perform as I would like it to. I want one that will pull the plane around better. Not something that will overpower it, but is an increase in power for use with the same ESC that came with it, which is an 18 amp ESC.
Any suggestions?
CGr
