RCU Forums - View Single Post - Panel lines
Thread: Panel lines
Old 12-09-2012 | 10:32 AM
Chad Veich
My Feedback: (60)
Default RE: Panel lines
I use the same method for overlapped panels and the results are worth the effort. I do use electrical tape instead of paper based masking tapes as the electrical tape will go around curves and does not disentegrate when wet sanding which I prefer to dry sanding. The hardest part of the process is often just figuring out in what order to proceed with application of the panels and then not accidentally building up on the wrong side!
