RCU Forums - View Single Post - A really small float plane build thread
Old 12-09-2012 | 01:48 PM
  #31
Bill G's Avatar
Bill G
Default RE: A really small float plane build thread
I've always wanted to try the Rufe conversion. After this project, you can pick up another Zero kit and build an AR196 conversion. The fuse really isn't too far off, with a bit of reshaping.
The dunkings really do stink. I had this one off the water and in the air, although it was a bit tough handling on the less that still water so I pulled up earlier than I should have. Almost saved it, and with an absolute perfect recovery, I may have been able to. All works after a quick dryout, and have yet to try it again.
ID:	1828259   Click image for larger version
