RCU Forums - View Single Post - Sig Ryan STA
Thread: Sig Ryan STA
Old 12-09-2012 | 01:50 PM
  #533
VincentJ's Avatar
VincentJ
Default RE: Sig Ryan STA
Thanks Robert for posting that for Steve. Good example of how the exhaust can ne modified to fit your needs/space.
I dodged a bullet tonight that I would like to share with you. As I stated earlier, tonight I wanted to lay down the Polyester Glass Resin under the cowl area. I used it last for my Cub and I liked how it hardened the wood and howit sanded. I remember last I used it besides the terrible smell the resin came out kind of clear and when you mixed the proper amount of catalyistit changed its color ever so slightly. Well as I poured the resin from its container I noticed that it was a little darker than what I remembered it to be and when I put the 15 drops of catalyist init didn't change color. WellI decided to stop and re-read the directions and I'm glad I did becausethe directionssaid that this product has a shelf life depending on the climate it's stored in and it could range anywhere from <u>6 months to two years</u>.I decided to use a bit of it onjust the cover hatchas a test thinking if it dosen't cure I can easily make another. Well hours later and guess what didn't harden. I'm glad thelazy side of me didn't just say go ahead put iton it will be fine...Looks like another trip to the LHS, but at least a disaster was averted.
