ORIGINAL: lupy
Fyi, dipping in corrosion X is the only way to go with float plane electronics. There are numerous threads on it, so I won't go into great detail, but I have never lost anything that was dipped before getting wet
Sorry to see your plane didn't work out, the tip floats really like to dig in, probably a little small. The other rufe sure flys nice, but the float looks way too long. Reminds me of a shoe. His tip floats aren't digging in at all though, so there might be some secret to them.
Yes, I've seen the CX threads and actually ordered some a few weeks ago to use in other EP float planes I have, the stuff works well in many aps you'd use WD40 for too.
I may play with it again, the day of that last video, where my kid is laughing at me, it was too choppy, I shouldn't have attempted it that day.
Several things to address
Main Float needs more of a step, and it needs to be sealed with a gloss paint, the water based flat I used just absorbs water like a sponge. I may use 5/8" oz cloth and Water based poly for that.
Tip floats are a issue also, yes,, I don't think they are too small, but I think they need a stiffer wire or need to be braced,, they move around to much and I think they are flexing back, which reduces the angle and then they dig in,, they also need to be glassed so the glide through the water better.
we'll see
