RCU Forums - View Single Post - Sig Ryan STA
Thread: Sig Ryan STA
Old 12-11-2012 | 03:44 AM
  #542
VincentJ's Avatar
VincentJ
Default RE: Sig Ryan STA
Welcome jawsmon, I have tried to cover most critical aspects of this buildin this thread which I'm sure will help you out. I would be happy to copy the instruction book for you if you pm me your address. Sounds like most of the difficult stuff,ie. the wing has been done. Reinforcement of the landing gear is a good idea. Oneidea/suggestion that I have for you is this: my guess is the original builder has used the supplied Balsa for the front and rear spars, since it's too late to change them out you could get some benefit from installing shear webbing on the entire wing, this should work well for you. Make sure the grain of the shear webbing is running vertically and not side to side. If you need assistance all you need to do is ask. Good luck and enjoy your build....
