RCU Forums - View Single Post - Smart-Fly single-receiver Ignition Cutoff
Old 12-11-2012 | 06:23 AM
rrritchey
Default RE: Smart-Fly single-receiver Ignition Cutoff
Hi,
I think you must be talking about the Fiber-optic receiver since its the only thing that connects to the ignition battery. The fiber-optic transmitter connects to a servo port on the receiver. A Deans connector is not needed because the current is so low so we only supply a Futaba female to the battery. You can plug in either a Futaba or JR male to this. You can make an adapter, you can use one of our SuperSwitches which has Deans on the battery side and JRs on the output or you can change the connector on the fiber-optic receiver.
ORIGINAL: jmcowart
I notice on the Smart-Fly web site that the Regulated Ignition Cutoff is made with a Fatuba battery connection on the transmitter. Is it available with a Deans Ultra connector? I want to use one with LiFE A123 pack for ignition and do not use Fatuba anywhere. Or am I way off base here for some other reasons. Thanks. Mike.
